I am going to do this swap (E4OD-ZF). However, I don't have a donor truck, it's all wrecking yard for me.
I have a couple questions that I haven't been able to anwser yet.
I have visited the local parts store to get an Idea of the cost and in doing so found a couple issues.
Flywheel and clutch size: they (SHUCKS) say that the F-150/Bronco came with either a 10.5" or a 11" clutch and the F-250 (4.9-5.8) came with a 11.5" only?
Basicly: Which would work?? I have only been able to find 2 different part numbers for flywheels. I THINK that the 10.5" and 11" share the same flywheel and the 11.5 uses it's own?? whatcha think??
Obviously I would like the larger clutch.
Master cylinder: SUCKS I mean Shucks (local store) said that f-250 and bronco used different master cylinders. Online Shucks say that they use the same.
Are they the same??? Anyone know??
I will be driving a couple hours to the wrecker who has the tranny and I would like to get the other parts from that truck as well!!
I thought that the Bronco only used 1 drive line?? Through searching here I found a couple people posted that there are different ones out there. I found the TRANNY thread and someone there said that they were working on getting a compatability list together?? Is there a list??
Does someone know if my E4OD driveline will work with the ZF or not??
All help appreciated!!
