1 - 15 of 15 Posts
Is anybody available to give a fellow FSB AZ Crew a little help with moving the front ttb axle forward 2"+ ? Don't rag on the ttb to bad, I already know it's not even close to being the desired setup, but right now that's what is in and I have to work with,until the swap. The front RA are back too far ( as per instruction) , but the springs and shocks are pointed to the rear as it is settling in. HELP would be apreciated.:banghead :banghead :banghead
9
Guest
Soo, you just need to move the rear R/A mounts forward 2" on the frame?
Just curious, how did you get the axle shafts in there if its pinched back 2"?
Is the long side wedged in the TTB window?
yes, the rear extended ra mounts need to move forward 2" and the yes the axle shaft is rubbing in the window. :doh0715:
Helping hands would be great. Sorry couldn't get back to you. I was on the road. Doesn't matter where it is done at just need to get it done before the big run. Thanks for the response.:whiteflag
Discussion Starter #13
Power and Brown in North East Mesa. I will be working on her this saturday morning before the "RAIN" gets here. If anyone would like to help it would be great. PM me
hey dude, pm chris85xlt I think is his name I belived he moved his axles up..IIRC
Discussion Starter #15
What a pain in the ars that was. Driver side no problems, everything nice and smooth. Passenger started the wrong way and continued to the very end. After breaking two ratchet straps and tweaking my back again, an extra long pry bar and heavy duty screw driver got the job done. The springs and shocks are now pointing straight up and in line. Thanks, to those that offered assistance.:twotu:
1 - 15 of 15 Posts
