a breakout box is just like the pcm connector harness side but eaiser to test at, what ever break out box pin it says to test at, just test at the pcm connector harness side pin, should get you the same results, plus your connector should be real easy to get to especially if you pull the fender well if you only got 3.7 v vref somthing is taking up some extra voltage that is in series with the evr signal wire, test ohms with a multi meter from the evr sig wire at the pcm connector harness side to the signel wire at the evr sensor connector harness side, do this with both connectors un plugged(pcm and evr), check spec from the pin point test your doing and compare. if that makes sense. hope so im not good at explaining hope it helps, i didnt read every reply so if someone already explained this sorry....
SLO,
I want to make sure I am understanding this right
VREF (pin 26)=Volt Reference and that is power
Sig RTN (pin 46)=Ground
EVP (pin 27)= EVP sensor signal to PCM
When I did the EVP circuit check (VREF and Sig RTN) at the sensor connector in the KOEO I recieved 5.0 volts. Haynes say that voltage should be between 4 and 6 volts, so I am good there. That tells me that I am recieving power to the EVP sensor and the ground is good.
Then I did the same circuit test between VREF and EVP and got 3.7 volts. I did not see that test anywhere, I just did that to see what would come up.
Then I did test DN7 "Check EVP Signalf or short to power"
-key off, EVP disconnected from harness
-I turned my DVOM to 200K
-Measured resistance between test pin 27 with 26 and 57.
I got nothing.... what am I doing wrong? DN7 asked if both are greater than10,000 ohms.
thanks
