Have 1992 Ford F150 with auto trans, 4x4 and 5.0l... bone stock...Starts and runs BUT...Runs Sooooo rich that it floods itself out...to date I've swap in a different EEC, replaced ECT, ACT, O2 sensor, PIP sensor, MAP sensor, New Wires, Cap rotor, spark plugs 3 times...Replaced the Fuel pressure Regulator and retested fuel pressure..KOEO 42psi...KOER 44psi
Ohm tested injectors 14.40 - 14.60
Map 157 hz
Compression test lowest cyl 140 highest 150
injector pulse width (cold) [email protected] 1000-1100 rpm's
(cold) [email protected] 800-900 rpm's
with the breakout box checked pins
#6 = 1.12ohm
#16 = 1.00
#20 =.93
#40 = .93
#46 = .99
#49 =.99
#60 =.83
Also checked voltages at specified sensors...all are reading good within normal varience..
Went through the WHOLE truck and cleaned all the grounds I could find...Disabled the fuel system and ran on injector cleaner and it fired once and ran about 1-2 minutes ..then wouldn't fire agin until we pulled plugs and cleaned them....
Is there something that I've missed that would cause this to run so rich???
I'm about to swap out the 8 injectors with 8 that I know are working correctly...
Thanks for any and all input
Dan
Map 157 hz
#6 = 1.12ohm
#16 = 1.00
#20 =.93
#40 = .93
#46 = .99
#49 =.99
#60 =.83
Dan
