1 - 3 of 3 Posts
Is it possible to pull CEL codes with wires already plugged into the EEC Test box? Every example I've seen, the box itself has nothing in it.
you have to either jumper the correct wires together or run a ground wire from the Self Test Input to the negative pole on the battery. I tried jumpering the STI to the GND on the Self test and that didnt work. So straight to the negative battery terminal for me works every time.
Give that a try and see what you get.
The STI is the single cable that comes loose from that connector cover.
That worked, thanks for the help Jowens
1 - 3 of 3 Posts
