After troubleshooting the fuel pump relay and the EEc relay due to no fuel pressure I discovered a wire at the EEC relay connector is broken. Actually butchered would be a better description. Previous owner spliced in a section in the "blue" wire which goes to the large connector that is inline with the two small connectors. Problem is the section of wire he spliced in has a tag stating "fuse link". According to Haynes, and Steve83's description, the Yellow wire is supposed to be the fuse link and the blue is for the EEC.
So is the blue actually to a fuse link? Since it is broken at the firewall junction do I replace it all the way to the injector wiring and Engine control module?
Still confused
Here is your pic
It should be close to this 1991 Bronco
http://fordfuelinjection.com/files/bronco_1991_49-2.gif
Fireguy50: Okay I must be blind as I do not see a EEC relay on your link. I see the engine control module etc but no relay. What manual is the page taken from? Guess I will have to go through wire manually to track it down, especially since I have to totally replace it.
How did you get my picture to show up?
Thanks
