Need help dialing in my truck. I would like to hear from people that have the same or similar setup. I have a fresh 351w bored .040, crane computer friendly cam, performer heads and EFI truck intake, headers, full exhaust, all my emmisons, and stock fuel system.
Truck ran great untill I put the new intake on. Now I have a rough Idle at start and after a couple of seconds the "Check" light comes on and the idle smooths out and holds at a grand.
I can drive the truck and it has a lack of power when I accel hard. RPMS will hunt after i let off the gas. I have pulled codes and it continues to say TPS volts, but I have tested it and tests good. I replace it and it tests the same. I've got good vacume and I believe the timeing is good. I have also tried cleaning the Idle valuve. fuel psi is a little low.
Is my fuel system not able to keep up? why is it running better after the check light comes on? am i pushing the limits of SD? Does anybody else have the same intake and how do they idle?
