· Super Moderator
Yo CannonH,
Or purchase an EGR Eliminator plug @ https://campaign.aliexpress.com/wow...3059182426&OLP=1085400208_f&o_s_id=1085400208
EGR Eliminator
Disconnect EGR Valve Position sensor (EVP), and inspect the harness connector. Make sure it’s free of corrosion and still has dielectric grease on the terminals. Plug the Eliminator into the EGR Valve Position sensor (EVP) harness connector. Zip tie the eliminator to the engine to protect it from vibration. This product only eliminates the EGR electrically. Please take the time to remove and cap off vacuum lines. If you are leaving the EGR valve on the intake confirm that it is fully closed. A leaky EGR will cause more engine problems. It’s best to remove the EGR spacer, or put a block off plate over the opening. When performing computer Self-Test after installing this kit it is normal to get code: 33 / 332 EGR valve opening not detected. The computer is acknowledging that the EGR is permanently closed. This is your desired result. However if you get the following codes: 31 / 327 - EVP circuit failed below the closed EGR limit of 0.24 volts 32 / 328 - EVP circuit failed below the closed EGR limit of 0.24 volts 34 / 334 - EVP circuit failed above the closed EGR limit of 0.67 volts 35 / 337 - EVP circuit failed above the open EGR limit of 4.81 volts Check your connection again; make sure there is no resistance in the harness. NOTE: This device is not intended for pollution controlled vehicles. Local, State, and Federal laws may prohibit the removal or disabling any emission control device on any emission applicable vehicle.
Product Font Auto part Electronic device Audio equipment
Product Goggles Font Screenshot Software
EGR Eliminator Disconnect EGR Valve Position sensor (EVP), and inspect the harness connector. Make sure it’s free of corrosion and still has dielectric grease on the terminals. Plug the Eliminator into the EGR Valve Position sensor (EVP) harness connector. Zip tie the eliminator to the engine to protect it from vibration. This product only eliminates the EGR electrically. Please take the time to remove and cap off vacuum lines. If you are leaving the EGR valve on the intake confirm that it is fully closed. A leaky EGR will cause more engine problems. It’s best to remove the EGR spacer, or put a block off plate over the opening. When performing computer Self-Test after installing this kit it is normal to get code: 33 / 332 EGR valve opening not detected. The computer is acknowledging that the EGR is permanently closed. This is your desired result. However if you get the following codes: 31 / 327 - EVP circuit failed below the closed EGR limit of 0.24 volts 32 / 328 - EVP circuit failed below the closed EGR limit of 0.24 volts 34 / 334 - EVP circuit failed above the closed EGR limit of 0.67 volts 35 / 337 - EVP circuit failed above the open EGR limit of 4.81 volts Check your connection again; make sure there is no resistance in the harness. NOTE: This device is not intended for pollution controlled vehicles. Local, State, and Federal laws may prohibit the removal or disabling any emission control device on any emission applicable vehicle.
Automotive tire Bumper Font Automotive mirror Audio equipment
EGR Eliminator
Disconnect EGR Valve Position sensor (EVP), and inspect the harness connector. Make sure it’s free of corrosion and still has dielectric grease on the terminals. Plug the Eliminator into the EGR Valve Position sensor (EVP) harness connector. Zip tie the eliminator to the engine to protect it from vibration. This product only eliminates the EGR electrically. Please take the time to remove and cap off vacuum lines. If you are leaving the EGR valve on the intake confirm that it is fully closed. A leaky EGR will cause more engine problems. It’s best to remove the EGR spacer, or put a block off plate over the opening. When performing computer Self-Test after installing this kit it is normal to get code: 33 / 332 EGR valve opening not detected. The computer is acknowledging that the EGR is permanently closed. This is your desired result. However if you get the following codes: 31 / 327 - EVP circuit failed below the closed EGR limit of 0.24 volts 32 / 328 - EVP circuit failed below the closed EGR limit of 0.24 volts 34 / 334 - EVP circuit failed above the closed EGR limit of 0.67 volts 35 / 337 - EVP circuit failed above the open EGR limit of 4.81 volts Check your connection again; make sure there is no resistance in the harness. NOTE: This device is not intended for pollution controlled vehicles. Local, State, and Federal laws may prohibit the removal or disabling any emission control device on any emission applicable vehicle. By absent member Fireguy50
Ford Bronco 1989 costum
Yo CannonH,
EGR Eliminator
) View attachment 209946
EGR Eliminator
Yo CannonH,
EGR Eliminator
EGR Eliminator
Can you show me a picture cause I can't find where it's at in my Chilton book but I'll keep looking thanks
· Super Moderator
Yo Cannon,
Motor vehicle Automotive fuel system Gas Auto part Electrical wiring
EGR Valve Location pic in an 89 Bronco by member waltman
Light Motor vehicle Automotive tire Auto part Gas
EGR Valve Location & Block-Off Plate in an 89 Bronco, by Street Truck, Crazed, Broke, OoG) at SuperMotors.net
