I'm trying to solve my idle issue. I cleaned the iac and replaced the gasket, and it idles better but not perfect. So I go to the egr valve and take that off and realize that there isn't a tube or anything connected to the bottom where I feel like there should be? Where dose this tune run to and is there a reason someone would have taken it off and not put it back on? Thanks!
In my '87 there is a slightly flexible metal hose from the bottom of the EGR to the top of the lower intake manifold. Unless your EGR is leaking into the upper plenum then it should not be causing a problem there at idle... However... The other end of that how connects to the lower manifold so I'm concerned that unless someone plugged it, it's a huge vacuum leak. Hopefully someone plugged it. You'll need a mechanic's mirror or something to check.
See how the lower pipe runs between the upper plenum and lower intake, in that scraggly heat wrap...
EGR Valve/Idle Issues
Hi, I have the same problem. I could not replace the EGR Valve Tube because we could not get the old Fitting off to put the new tube on. Someone helped me do this, and he said he welded it shut, but that's not the truth. He just squeezed the tube. I think it's sucking air, and causing the feeling of a vacuum leak. I would like to fix it properly, but I am having trouble finding the assembly.
yo,
ADAPTER to Lower intake from EGR Valve in a 96 5.0; "...Parts MNGR said it still available @ a few dealerships but is Obsolete, He said the Price is $34.99; Ford MC PN N803575-S51 "22mm";On-line search I did just now gives one good hit (so far): CONNECTOR - Part Number N803575-S51 - asked the manager if the 96 5.0 Adapter is same as earlier years 5.0 engines and he said, "Yes", 4 JUN 2010"
Source: by miesk5 at FSB http://fullsizebronco.com/forum/showthread.php?t=173088&page=3
Part: N803575-S51
Availability: 103 found at 5 sellers
Price Range: $20.75 to $20.75
http://www.rearcounter.com/N803575-S51-parts228885.html
Ford Truck Air Tube (EGR)
Ford Truck Manifold Tube
•Two threaded ends and mid-pipe flexible coupling.
•85-94 Ford trucks, 5.0L 302 eng.
•Replaces O.E. E5TZ-9D477-B.
114 Ford Truck Air Tube (EGR) qty: $32.18
http://www.pciinc.com/application_search.php?selected_make=FORD+TRUCKS+A-E&selected_model=BRONCO&app_action=select_mfr
EGR Tube replacement http://www.fullsizebronco.com/forum/showthread.php?t=183964
The tube itself looks like this.
You have to remove the upper intake to get to it.
Heres where it connects. You can see the tube is wrapped in a black fiberglass jacket, it used to be white.
There was a big crack in the accordion section of the tubing.
yo,
86-95 5.0L EGR Tube
Item Number: 30080
Unit Price: $55.00
New EGR Tube for 1986-1995 Ford Truck or Bronco with 5.0L (302ci) motor.
DOES NOT WORK ON CALIFORNIA TRUCKS!!!
This EGR Tube is durable against stress fractures, corrosion, and blockage from carbon buildup. Some models have been re-engineered to include a modified flex joint that reduces the possibility of damage due to heat and vibration.
•Includes sheathing to protect electrical components from heat damage (where applicable)
•Stainless steel construction ensures long-lasting performance
•Direct replacement for a proper fit every time
•A rigorous quality inspection has been undertaken to ensure that this part conforms to product standards
http://shop.broncograveyard.com/86-95-50L-EGR-Tube/productinfo/30080/
90-97 5.8L EGR Tube
New
Item Number: 30082
Unit Price: $29.99
1990-96 Ford Bronco
1990-97 Ford F150, F250, F350
EGR Tube New
1990-96 Ford Bronco
http://shop.broncograveyard.com/90-97-58L-EGR-Tube/productinfo/30082/
EGR Tube (also called, AIR Tube), Crossover Tubes, Check Valves, O2 Sensor Repair Bungs, High Temp Silicone Hose, etc. for Bronco & all Ford, w/Ford Part Numbers & pics; miesk5 NOTE; "...EGR, Source: by PCI Inc
great customer service!! they sell direct or thru NAPA, etc.
