Sorry for the delay. Little dude has been home from preschool due to a covid scare (thankfully no one here is sick). But! ive got some pics for you.
driver caliper:
passenger caliper:
cables route past inside of shock
clip holding cables to frame. This is actually a suzuki part, but only because i had this laying around (and couldn't find the OEM cable bracket).
tensioner bracket. This is intentionally offset towards the top of the frame, to make room for a set of as-yet-not-built rocksliders.
close up:
So i modified the tensioner, so it would work with the stock cable off the pedal. Basically, i welded a nut to the end of that 5/16 fine thread stud, and then carefully ground a radius into it, so it would work with the OEM retainer for the OEM pedal assy cable. Thus far it seems to work good, altho the truck has maybe 20 miles on it since i "finished" it. Long term, i think i want to modify this to add a return spring, since the 80-91 pedal assy doesnt have a return spring in it like the 92+ pedals do.
