1 - 11 of 11 Posts
I have a cooling fan set up for a 2 row rad. Has a seperate wire that be used to turn the fan on when your A.C. kicks in or It can be run to the dash when you want to be able to turn the fan on. The thermostat on the fan is adjustable the second fan only kicks in when the temp gets 15degreese above the setting on the first fan
They work great if fact they work to well for where I live
300 or best offer + shipping SOLD
Discussion Starter #2
This Fan kit will fit 85-96 Ford Bronco with 5.0 or 5.8 Engine,will also fit the 85-97 Ford F Series Truck with the 5.0,5.8 or 7.5 Engines. This is a really nice kit that will enhance the performance of you vehicle. This kit like all our others,is designed to bolt in like a direct factory fit. The shroud is made of .080 5052 aluminum for strength,durability and appearance. The fans are 13" Spal Fans rated at 1700 CFM x 2 They will draw around 17 AMPS EACH. The Derale controller is the brain behind the kit,it is an adjustable controller with an A/C override,we also send along an upper radiator hose inline adapter for the temp sender for the controller. This is a great kit to either improve fuel economy or horsepower.
PM Sent
1 - 11 of 11 Posts
