1 - 20 of 25 Posts
Like the title says - which circuit in the fuse block would y'all recommend that I tap into for the 12V that the choke wants? Half of the ones there are key-on power, but which one do I pick? Don't think the accessory is a good idea, so what else works with the IGN but not on the ACCY positions of the ignition switch?
The stock choke wires to the stator output on the alternator, it's only about 7 volts. If you wire 12 volts to the choke you'll burn it up. Aftermarket chokes can hook to any switched 12V circuit.
It's a 1403 carburetor, it wants 12V, that's why the stock wiring won't work. I'll see which one is easies to access in the fuse panel and tap into that.
Salt-Man
all that I did when I installed my edelbrock carburetor #1406 with electric choke
was I used a meter and found a wire in the engine compartment that was
energized by the key and had 12volts.
but if you are running a new wire to it you should be able to find a extra
connection at the fuse panel or tie into something like the radio fuse or something similar
as long as it is 12v and comes on with the key I wouldn't think it would matter?
that choke is not going to be pulling alot of amps or anything
you just do not want constant power to it
Discussion Starter · #9 ·
Aight, I tied it into the B/U (backup lights?) cicruit - that one is key-on 12V power, so it should be good. I already had the hole for the speedo cable which I also used to run the line for the vacuum gauge and the wire for the fog lights, so I just ran the choke wire through there too and added wire loom to prevent the wires from getting cut. The cool thing was that the fused side of the B/U circuit had no wire attached to it at all (dunno why, that's how it was, open circuit), so all I had to do was crimp a ring terminal to the choke wire and literally bolt it to the terminal in the fuse block, a small self-tapping sheetmetal screw worked great for that.
Larston, on my '78 the wiper motor is inside the cab, so your trick wouldn't work for me.
Discussion Starter · #11 ·
Well actually it wasn't fixing, more like upgrading - carb came with the electric choke, but I already had the manual from the old one routed and trimmed, so I ran the manual one for a week to give me some time to tune the carb, and now that it's working good I could go electric like tis supposed to be. It works good too, takes it about 4-5 minutes to open all the way, which is just as long as it takes the engine to warm up too, so I'm pretty happy with it now.
Salt-Man
What I meant was you don't want constant power to it at all times.
you only want it to energize the choke when the key is on
Salt-Man
Thats Tonto to you Kimoslobby !
Hey Lone Ranger when do you get you Bronk Silver back ?
When you get in it and drive it for the first time are you going to scream
" Hi Ho Silver Away! "
You sure you don't do drugs anymore ya phat bastard?:goodfinge
I don't know when she comes home. Hopefully before spring. I really don't want it home right now anyhow, got no place to park it.:toothless
1 - 20 of 25 Posts
