i just went to the 4wp website and read about the above air compressor that dogonmut posted. they also list a dual cylinder gta model for $179 that they say is 50% faster than the gtamv50 (gtaQ-89), but the description is thoroughly confusing and seems to contradict that:
GTAMV50
This sturdy air compressor is perfect for Trucks, SUVs, RVs and other full-size vehicles and is designed for everyday use, from blowing up your kids' soccer ball to filling up a flat tire. The MV-50's 12-volts of power and 150 PSI capacity is comparable to other higher-priced compressors.
Single Compressor Details:
0 – 35 PSI in 2 minutes
12 volt, Max 150 PSI, Flow up to 72 lpm (liters per minute) – 2.543 CFM Max Amps 30 Individual weight: 8.8 lbs. 10 ft. power cord to reach around the vehicle, Detachable hose 16 ft long, Built in pressure gauge, Needle adapters includedAlligator clips (color coded) to hook directly to battery,Bonus carrying case.
The
Q-89 is a 12 Volt Hi-Pressure Portable Air Compressor. Q-89 inflates tires 50% faster than the MV50.
It may inflate a 35 x 12.5 x 15 size tire from 10 PSI to 35 PSI in an average of 4 minutes. This unit is equipped with 16ft. coil hose with a tire gauge attached to the hose, extended power cord, and soft nylon carrying bag.
Specifications:
Motor: 12 Volt DC
Maximum Power: 47 Amps
Maximum Working Pressure: 120 PSI
Direct Drive, Reciprocating Engine
Maximum Recommended Continuous Operating Time: 40 minutes
Recommended on/off cycle time: 20/30 minutes
