The motor on my transfercase stoped working. I can feel it turn but wont loke i. I tried smaking it with a hammer and didnt help. I found a transfercase out of a 95 f150 thats manual shift. I can get the linkage shifter and case for 120. Would i need anymore parts to swap it. Would it be worth the money. I can probably get the hubs too. Would it work sense im not sure what trans was in the truck but it was prob an a4od. Also if it can be done what would it take?. Can anyone give me a link or something that tells me in detail the steps?
If you've got the same trans it'll all bolt up. You'll have to take the output shaft from your t case and swap it from the f150 because they're different. Broncos have a flange while f150s have a slip yoke. There are a million threads on it, I've even got info in my build thread. Can't link off my phone though sorry.
Nobody likes the shiftster because you have to get under your truck to change gears, not an issue for a trail rig but a big PITA on the street. It could be rigged up with a cable though.
Charlie don't surf..
'92 Ford Bronco XLT
like cw said, you'll need to swap your output shaft to the manual case along with the tailshaft housing..
make sure to get the linkage and bracket for the manual case as well, and if you want the 4x4 light to light up on your dash make sure to get that harness as well.
yo GJ,
As Jer advised;
1356 Electric Shift to Manual Shift Swap in a 95
Source: by Shadofax (TheJuice, The Juice, Mark Z) at
http://www.fullsizebronco.com/forum/showthread.php?t=66992
1356 Electric Shift to Manual Shift Swap in a 90 (Minimal Narrative, no pics)
Source: by Rade at http://web.archive.org/web/20081119041702/http://2bigbroncos.org/technical/manual_hubs.html
1356 Electric Shift to Manual Shift Swap in an 87
Source: by Joey S (Nacho, Stokes, Larry, Stoked) at http://www.superford.org/registry/vehicles/detail.php?id=3287&s=16394
1356 Electric Shift Troubleshooting & Repair - BEST PROCESS! by FORD via http://www.revbase.com/BBBMOTOR/TSb/DownloadPdf?id=35193
Thanks everyone for the input. The transfercase was missing the linkage and he didnt know if it worked so i think i am going to give that shiftster a try until i can get a manual case to swap. I am planning on getting hubs though. I have a pdf file on the swap. I have 5 bolt hubs and the manual are 6 bolt. That wont matter will it. They are facotry ford hubs
