whats the best way to find a draw from the battery. i have to jump start it every other time any help would be appreciated.
make sure the battery is good first, you can bring it in to an autoparts store and they should check it for free, call first.
If the battery checks out OK, I would start by pulling fuses one at a time and seeing what effect that has on the system. Do you have a multimeter?
i do have a volt meter. and im not sure if its the battery because after i get it jumped the battery gauge in the cluster reads about 14 but i will check. anything else i might be able to try.
