1 - 4 of 4 Posts
ok, i don't think this makes any sense, but here we go...i've noticed that when i put my left power window down, or put my left blinker on, my Subwoofer cuts out for a second or two...but not when i touch the right side window, or the right side blinker...does that make any sense?:tinfoil
If there is one thing I have learned about electrical problems, they usually dont make sense.
I'd check the sub/amp wiring to see if it is crossed into something else somewhere.
sounds like a ground issue. Your ground is not good enough to handle 2 loads at the same time.
You'll need to get up under there, it'll help to remove the seat... Look for your grounds (where wires attach to metal) and look for a loose connector, corrosion, or a broken wire.
good luck
1 - 4 of 4 Posts
