I haven't started my bronco up for about a year, it overheated and I just let it sit till I got around to it.
Anyways, I put in a new battery and starter solenoid and it still won't crank. It will make a clacking sound an that's it. I've always had problems with the solenoid in the past, but I want a permanent fix for it.
I've tried crossing two screwdrivers on the solenoid and I do get a spark, however I can't get anyone to help crank it when I'm working on it. The battery cables get untouchably hot if I try to crank it multiple times in a row.
Check the wires running to the starter. Does it have a good ground etc. Does the Bendix engage then not crank? I would check your wiring to the starter for the hot wire grounding out or the ground not being grounded.
-Adam
The fender well solenoid needs a good ground. You should be able to crank it by using a jumper wire to put power to the S terminal in that solenoid. If it's a manual trans try putting it in second or third gear and rocking the truck to see if the engine will turn just a bit. I hope it's not locked up. If so, try pulling the spark plugs and shooting some PB Blaster in the cylinders.
It's an auto. This thing has been in the family since it was new, and it has been left to sit on several different occasions, locking up was never a problem in the past, from what I know.
Which post on the solenoid do I need to lead the ground off of?
Im scared of jopes
If your wires get way to hot to touch then I would replace them because they are probably corroded inside from sitting so long. Get a gauge bigger or so, Or it is because your starter is sucking way to much juice. I also see you just replaced battery and solenoid, Maybe try a new starter, I cooked 4 stock ones in 4 weeks with my 460 because of compression and I believe they heated up way to much. It would just clank and make funny noises trying to start it, Now I got a mini high torque starter and haven't had problems since.
