Electrical Problems
526 Views 2 Replies 3 Participants Last post by  Bronco4Life
I am having some issues with my 82 F150. I turn the turn signal on for the left, and both of them come on, I turn the right turn signal on, and it works fine. Also, instead of the actual turn signal indicator coming on in the dash, the e brake light comes on for the right one, and the seatbelt light comes on for the left side. What is going on? I dont like doing electrical, but in the same token, I am not gonna pay someone to do it either. Any help is appreciated.
1 - 3 of 3 Posts
sounds like the signal switch in the columb is wore out , turn it on and wiggle it a little to see if anything else happens.
OR try replacing the signal relay / make sure the bulbs are good / all conections are good / all fuses are good/
before thinking you have a major problem PLEASE look for the smaller more common problem. my2
Bad grounds. Check em all.
1 - 3 of 3 Posts
