ook my blower, turn signals, and rear defrost went out all at once...
none of their fuses are blown.. unless there is a fusable link hiden somewhere...
all their fuses are in the same area on the fuse panel, could i have screwed up a section of it? ill go pull it off in a min and check, just throwin the idea out there..
anyone else lose these things all at once as well?
i want heat! its friggin cold here in maine!
oh yeah and turn signals would be nice ;)
FSB warrior
I have my 81's fuze panel cut out so I can hold it in my hand, and one of the things ive learned is that a section of the fuze panel (only 2 are like this) has a metal bar that goes between fuzes, with one big wire supplying power to that area of the fuze box. If that wire is messed up or a fuzeable link is blown that could be the problem. The best area to look for fuzable links is on your starter solenoid(the smaller wires)
im magic i guess, the fuses wernt blown so i pulled the whole fuse box and looked up the wire color to the wires for the blower and defrost and stuff, and low and behold they were all right next to eachother like i thought and all i had to do was wiggle them and put it back in... everything works great now...
