1995 5.8, 2.5" Rough Country Lift, Extended RA's, 4.10's, 33" BFG's
Sup Guys?!
Yesterday I put the Bronco in 4 wd. I pushed the button and nothing, no clicks, no lights no nothing, tried a few more times and finally she went into 4 wd.
I drove a couple hundred feet to make sure my new hubs were working, turned off the engine.
20 minuets later I starter her up, I noticed none of the 4 wd lights were on, no dash lights, no button lights, nothing. I tried to shift out of 4 wd and got no relay clicking or anything else and it was stuck in 4 low.
I checked things out underneath and noticed the insulation on the speed sensor wiring was in terrible shape, most of it was missing(crumbly and dry rotted)but the wire itself was intact and I made sure none of them were grounding out, but still a dead system.
So, I gave up for the day and began to research this problem, found Steve83's t-case diagnosis page and was ready to go at it this morning.
Jumped in the truck this morning and turned the ignition on and everything worked, dash lights and button lights were on and it shifted right out of 4 wd.
So, to me this sounds like a possible ground problem but what grounds do I check?
Also, could the crappy insulation on the speed sensor wires be a problem?.
I've got a manual t-case sitting in the garage but till I get it in I'd like to have this one reliable.
Thanks
J
Thanks
J
