As the title says, I've officially started my SAS and general truck build! :chili:
I really haven't done anything since I've purchase it because of building a garage and not wanting to do it half way. Finally, this past Sunday I spent about 5 hours taking all the front suspension apart (pics below) so there's no turning back now and this week I'll take the back apart for the shackle under. This weekend (Memorial day weekend) I'll start putting the front back together with some help from a couple other members. Not what you'd call a budget build, but not too crazy either. I've been buying parts for the last 12 months or so to spread the costs out, and now with my wife 8.5 months pregnant, I figure I better sh!t or get off the pot. My plans and parts list are shown below...
I'll continue to update this post with things I've forgotten, but most of the pics and status will be down in the posts somewhere. I'll have a spreadsheet that lists all of these parts as well as part numbers, prices, vendors, and I'll post that up as a PDF as I continue to get the little things done and updated.
Front Axle / Suspension:
- '78 High Pinion Dana 44
- Totally rebuilt end to end (for all the trouble, it seems like it should be more than one line item)
- 4.56 gear set with ARB carrier
- Stock shafts (for now)
- Alloy USA needle bearing u-joints (the JBG verbage fooled me)
- T-bird calipers w/ BC Bronco banjo bolts
- Cage radius arms for the "C" frame trucks
- Cage progressive 6.5" coils
- Heavy Duty JBG early Bronco spring towers will be extended to give ~12" of height above the bottom of the frame to give about 6" of total lift
- Custom trac-bar mount a-la Shadofax/Crazed from 2"x3" angle & 2"x4" rect. stock
- Custom milled spacer on the axle end.
- Custom Trans-mount from 3x4 angle and 2x4 rect. stock (hoping to continue it into a nice skid plate)
- Steering is 1.5" x .5" wall HREW tubing w/ Chevy 1-ton TRE's
- Tie Rod = 55” center-center OR 46-1/4” tube length
- Drag Link = 35-1/2” center-center OR 28-7/8” tube length
- Trac-bar is 1.5" x .5" wall HREW tubing w/ 7/8 x 3/4 bolt Heims and stainless mis-alignment spacers
- Trac Bar = 34.75” center-center OR 30.75” tube length
- Bilstein 5125, 14" travel shocks (two)
- F-250 Shock mounts (one per side)
Rear Axle / Suspension:
- Stock 8.8
- 6" shackle reversal from Ruff-Stuff
- Stock Shock mounts with 12" Bilstein 5125's
- 4.56 Gear set
- ARB Locker
- Stock brakes (will go disk later)
General / Appearance:
- 17x9 Pro-comp black wheels with fake bead locks
- 35x17 Mickey Thompson MTs
- Bronco Air front bumper (no winch yet)
- Bronco Air rear bumper (integrated with class IV hitch and with small rear winch)
- Custom tire / gas carrier (parts list later)
- Bronco Air OBA kit (with this, I've now paid off Bronco Air's college loans)
- Sliders from Boondock
Pics start in the next post:
- Stock 8.8
- 4.56 Gear set
- ARB Locker
