Darn, you’re too quick Mark… A guy can’t get away with anything on here…
I can’t believe I forgot something else. I haven’t been checking my parts list as much lately because I thought I had everything I needed and was too caught up with the tear down/install procedures. I ended up ordering extended stainless skyjacker pieces for a stock ’96 from 4wheelparts.com. They should be here Tuesday or Wednesday because of the long weekend. It will take me that long to get the steering links cut, drilled, and threaded anyway since I have to take it to a machine shop for the drilling. (a lathe is down on the down on the list a ways)
I did get a few more things done last night. I finished getting the rear spring hangers off, opened up the stock bolt holes to 1/2” and mocked the new shackle over mounts into place. I needed to cut about a 1/2” off the bumper mounting bracket to be flush with the forward edge of the mounting bolts for more room, and I’ll likely have to clearance the bracket itself about 1/4” so that everything will fit flush against the frame. The holes in the bracket are not perfect, but they shouldn’t be off more than a 1/4”, so I should be able to open up two of them without any trouble. The biggest problem is that two of the bolt heads will be hidden behind the gas tank. I’ll have to try and figure out tonight if I can get a socket wrench back there, or if I should weld a finger type flange onto bolt head so I can just pull them through with wire and keep them from spinning. Or if all that is too much of a big deal, I’ll just drop the tank. Of course it is about 2/3rds full though.
I painted the shackle hangers and my axles, so I can put the U-joints in tonight or tomorrow.
I also finished my lower tracbar spacer. I might have to take some more off of it for clearance issues, but at least it’s the right depth and has all the machining done on the face. If nothing else, this should make it easy to make it double shear in the future when I get some more time. It should be as easy as cutting and welding a piece of angle to this piece and then having it run down to the axle tube. I might look doing it now if I have time, but that not all that likely at this point.
Which bring me to my other issue… I haven’t gotten my axle back yet. I was supposed to be last week, then Monday, then Wednesday, then Thursday, now today. I’m going to be pissed if he doesn’t have it done. I guess it won’t hold up the main radius arm and spring tower fitments, but it would be really nice if I could put the axle back together this weekend while I’m going to have some help around and not have to worry about it anymore.
I’m being too long winded, and I have pictures to add in later, so I’ll clean this up then.
Don
Don
