1 - 8 of 8 Posts
I know this answer is in the threads somewhere but I have not found it. I am installing the axle pivot bushings and I am not understanding the instructions. The attached shows in 4.3133 part 3119. Does part 3119 go under the metal flange on the front or does it go on the back after I press the rest of the parts in? Thanks for any insight on this. If I had to guess I would think it goes on the back after the rest is pressed in. Man the grease they supply with these things is super sticky.
I tried to use these, could never get them in. Went picked up some Moogs, had them in in 5 minutes. Used regular axle grease.
I can get them in. I just need to know the sequence of parts.
I just installed these a few weeks ago. It goes on the back after the rest is in. There is a lip on the metal support cup that it pops over. The grease they supply is great and terrible at the same time. Its very sticky and easily makes a mess but it's very effective. Does not wash off with water, oil or even brake clean. It is resilient stuff.
Reactions: cobrajoe
Ultra Premium Member
I'm running Uni-Balls and I like them a lot. In all my years of playing with these rigs, I have never tried them. Very curious to how they hold up; we all know the stock rubber ones suck.
Thanks. That's what I thought. Really appreciate the response.
That's what I should have done. I'll keep u posted on durability.
Addicted to Junk
Thats because its not grease. Its silicone lubricant. Solvents are the best option of clean-up.
1 - 8 of 8 Posts
