1 - 9 of 9 Posts
Well my 96 bronco decided to throw a code yesterday. P0133 cheep code reader said bank 1 sensor 1 check slow response. I'm guessing that's a O2 sensor? Just trying to confirm for sure before I start throwing parts at it. Also not sure what side bank 1 is.
Thanks again
Thanks for the link, if I am understanding it correctly it's the passenger side? Also a quick google search said to replace both sides. Any reason to do that? Last question dealer parts or just go to auto zone?
yo,
Fords naming convention is that; bank one is the same bank as where the number one cylinder is on passenger side; by broncojoe19
Official Ford Parts Site - Motorcraft & OEM Ford Parts Online FordParts.com
http://www.fordparts.com/Commerce/CatalogResults.aspx?y=1996&m=Ford&mo=Bronco#Search
Stop by local Ford dealer parts dept and verify Ford PN
9G444 (DY-1094)
Oxygen Sensor 5.8L; 482mm long appears to be between cats
Dimensions: 8.25 IN x 7.50 IN x 0.00 IN
9F472 (DY-832) Oxygen Sensor
5.8L 351 CID 8 Cylinders @ Exh Manifold
yo, Forgot to answer directly instead of the wishy-washy crap
DY-832 APPEARS correct for passenger side exh manifold.
Perfect thanks! Any reason to replace both sides? Few searches recommended doing both but thought they either worked or didn't??
Ordered both sides, figured doing it myself saves enough to justify replacing both. Thanks again for the help
1 - 9 of 9 Posts
