Hey All,
I have been recently trying to figure out compression for my 351W build, so I have been using the Compression Calculator at www.JeepStrokers.Com
The direct link is here... http://www.jeepstrokers.com/calculator/ Just input our engine specs and you will have static and dynamic compression ratios. As best as I can tell, the specs for my 88 block are...
8 cylinders
4.0" bore (stock)
3.5" Stroke (stock)
combustion chamber depends on your head, I used 60cc for gt-40 cobra heads
.023" Deck Clearance
Gasket Thickness depends on your gasket
Gasket Bore Same as above
Dome/Dish/Valve Relief depends on your pistons
5.956" connecting rod length
your cam specs
Check it out, I have found it very useful...:thumbup
I also own a 2001 Jeep GC with a 4.5 Stroker that I built, thus the Jeep Strokers website reference:brownbag.
Bratcop
8 cylinders
4.0" bore (stock)
3.5" Stroke (stock)
your cam specs
Bratcop
