I had a problem of my 96 A/T killing as soon as I put it into anything other than park or neutral. I thought that the torque converter clutch may be the culpret so I put a new Torque Converter in. I now have Reverse and First but still kills as soon as put into Second or Drive??? Hoping someone out there can throw me a life vest as I am spent!
you pull codes?
Worked on it a majority of the day. By the time I cleaned up and went to take a test drive the auto store was closed so I wasn't able to pull the codes.
ok I have the same issue, I did adjust the idle screw on the TB to get it to idle, around 8-900rpms. I put it in gear and it luggs hard, around 4-500 Rpms and will not stay running. If I give it gas the motor revs and runs great but will not idle in gear with the brakes held or just idling along.
