1 - 3 of 3 Posts
0 to hero in 94563.1 sec
i was wondering if anyone has installed a trans oil cooler as a engine oil cooler? is this feesible and how would you do it?
Stuck like a MoFo
It works alot better with a cooler. IT also doesn't break down as much. Tranny cooler has too small of ID in its tube, oil coolers are closer to 1/2" ID. BTW They are great, mine brought the pressure up at idle when hot baout 5lbs and hot higher rpm 10lbs.
1 - 3 of 3 Posts
