That's right. As some of you know I have had some seriously bad engine problems since I bought the truck. :banghead Since day one I have had a major blow-by problem. Known by the amount of oil blown into the air-box. I was told then that I should rebuild it. But didn't. So I just learned to live with it and continued to drive the truck. That was almost 3 years ago.
Recently I have started to notice that my engine has been running rougher then usual, and getting hotter than normal. So I took it in to have a compression test done and determined that I was only running on 6 cyclinders :doh0715:. Mind you this is a 302. It was time to go.
Well to it's rescue is a 92 F-150 302 with 50,000 miles :shocked going in. An older guy owned it and used it to run to the store and back in a small country home. He got rearended and decided to part it. I bought the engine for 300 bucks and it's going in this week, ofcourse after some freshing up, swapping some parts over and new fluids.
opc1:
That's all Carry on with your day.
