1 - 10 of 10 Posts
I have an 89 with 4.9 L straight-6 c6 tranny. Can i swap for a 90 302 V-8 and and keep the c6 tranny?
My first post here! I'm resurrecting my Bronco after two years of sitting idle after blowing the engine in the Absorkees!
What if it is not? Any good souces for flex plates? I haven't seen the engine yet, so don't know if it on a c6 or AOD.
I'm presumign this would be a straight forward swap. Anything else I would need to look at? I'm thinking mounting blocks... Thanks!
shibby
Different offsets between the flexplates. You can get a new one at your local parts store. A C6 and E4OD uses the same flexplate and the AOD is different.
oops soory i meant the E4OD. Can I use the same flex plate then?
Also do I have to look at an engine balancer? . The engine I'm putting in is coming off a E40D onto a c6.
1 - 10 of 10 Posts
