1 - 10 of 10 Posts
Ok here's what the bronco's doing and what I've done. Wife was driving it and it died. Got it towed back home and she tried to start it back up. Starter cranked over but the engine didn't fire. I was out at sea when this happened. The ground wire ended up melting so she replaced that. I got back and went to work on it. I tried to get it to start but I wouldn't even crank the starter over. Turning the key wouldn't turn the starter over(not even a click) but if I jumpered across the starter relay with the key in the run position the starter would crank but the engine wouldn't fire. None of the acessories i.e. headlights, radio, rear window, door locks, door windows will work but the hazards do. I replaced the starter relay and ignition switch and still got nothing. If anyone has an idea I'll try it. Thanks.
Sneaky Ba$tard
I thought I just replied to this?????? must be nuts--Fog
Edit---I'm not nuts it's in here twice?????(well maybe a little but hay....)Fog
Navy? Just wondering. I am Navy and in San Diego, had some similar problems with my '85, took a while to figure out but I learned a lot doing it. Would like to help if you are in the area, if not we can try over the computer.
One of the problems I had you might want to check: the insulation on the wires in the harness just started falling apart from age. Caused some nasty shorts. More than anything you need to find where you have voltage and not. May have to start disconnecting things to find what is killing everything else.
Good luck and keep us posted. Let me know if you are in the area.
I'm stationed in Kings Bay, GA so I'm about as far from you as I can be. Thanks for the offer though. Hopefully I'll get some time to work on the rig this weekend.
Discussion Starter · #9 ·
The bronco is an 84. The door ajar/seatbelt buzzer works off and on also. With the key in the on position nothing works except for my hazards.
Discussion Starter · #10 ·
It's alive once more! I found where a previous owner had (I think) burned up a fusible link and just wired in a splice to finish the circuit. Only problem with that was the original wire was 12 gauge and the splice was 16 gauge. For some odd reason the splice decided to melt itself. Well fixed the problem and now she runs great. Found the splice while looking for shorts/loose connections. Thanks for the all the help.
1 - 10 of 10 Posts
