1 - 2 of 2 Posts
Hey there.I have a 81 Bronco with 351 Engine.And I have a 77 F250 with 400 Engine.Is it possible to fix the 400 into my Bronco and is there a big differenz between them?
Second Question: is it possible to change from automatic to manual transmission, and if yes how difficult is it.
Thanks
Norbert
Yes it is possible. You will need the tranny from the 4oo and the mounts as well as it is a big block and your 351 is not. Going from an auto to a manual is not hard if you know what you are doing. Dont take this the wrong way though, since you had to ask, it is probably too hard for you. You will need the pedals, slave cyl, master cyl, line, clutch, p-plate, flywheel, and fork. Since you have that style bronco, you will also want to contact your local Stealership and get the tsb kit for the firewall support for the master cyl.
Chris
1 - 2 of 2 Posts
