Don't know anything about an advance function in a timing light. Just get an inductive timing light. It just clips on the spark plug wire, way faster than the old style where you had to unhook the plug wire and hook up the liht between the plug and plug wire. The advance on your 90 can't be adjusted. You can measure it by checking your timing with the SPOUT connector unhooked(base timing, this is how you set it) then check it again with the SPOUT plugged back in. You should be able to get a decent timing light for $20 or less.
