1 - 13 of 13 Posts
The bushing in the last hanger is ripping apart. Can i buy these things aftermarket? My exhaust system is fine and the metal hanger is find but the bushing is screwed. How do I get that damn oin out (appears to be a rivet)and where can I buy the bushing?
They're a chain of parts stores in Southern AZ.... may not be up in Gilbert. They seem to stock better quality parts than Checkers.... and I just about refuse to go to AutoZone....
Gacknar said:
You can find them on the exhaust isle of any parts store.
You just lube it up and push the bushing off.
Does the pin push out? It does not appear to...has a head on one side and a bit of a lip on the other. I figured I'd have to cut it and replace it with a bolt and locking nut.
btw, Advance auto Parts pn for the insulator (bushing, 2 reqd.) is incorrect; Part Number: 35460 is diff than the stretched donut type needed for OEM and Walker EXHAUST HANGER Part Number: 35502
See Walker's site for images & PN's (35460 is shown + other parts needed if rusted) http://www.walkerexhaust.com/catalog/ExhaustCouponScreen.asp
if you want to go to SS for the hanger, try PCI's product
http://www.pciinc.com/partdetail.cfm?pn=1058
btw, had to unbolt the upper bracket to get to the hanger/insulator to replace them last year; the 2 bolts are metric
1clean5.8 said:
lube it up pry it off
:histerica :histerica :histerica :histerica :histerica :histerica
The answer to so many questions!
1 - 13 of 13 Posts
