1 - 11 of 11 Posts
im doing the bassini Y 3" exhaust. Are both sides of the stud metric? and what size thread are they?
Discussion Starter · #2 ·
anyone? c'mon just looking for a size. its looks like 7/16 or 10mm not sure because both are really close and the rust does not help the identification
Kitteh Commandaar!
Dont
me, but I believe the studs that hold the manifold to the head(s) are 3/8.
The bolts that hold the manifold to the head are 3/8. The studs that hold thr Y-pipe to the manifolds I beleave are 7/16. 7/16 are what I put in mine but they needed to be drilled and tapped so they might not be stock.
Practicing Infidel
Yup definitely 7/16" UNC (course thread)
Don't forget to use brass nuts so they'll come off next time
Sixlitre
Discussion Starter · #8 ·
thanks all went well got the studs out and put new ones in and it sounds great and i can feel the power!!
Practicing Infidel
Exxxxxxxxxxxxcellent !
What muffler and tailpipe did you use ?
Sixlitre
I just used all thread on mine. I chased the threads and they work great, and are CHEEEP. now if they hang, I can blow them out or drill them since it is softer metal. Just an observation note.
1 - 11 of 11 Posts
