Since I bought the Bronco I always had low power at the high end and suspected it was the catalectic converter
I recently ordered a Bassani Y-Pipe with a high flow cat. When they arrived I started pulling apart my old exhaust and opened up the cat to see what was inside. My suspicions were right.
I previously installed Summit shorty headers and will leave that part out but just so you know, they are there. I spent a few hours cutting our the old exhaust. It fought me all the way. The worst was a completely rusted u-bolt on the return flow tube the is above the cat and hard to reach. I ended up using a Dremel and about 8 cutoff wheels. I couldn't find the good fiber ones so I just kept braking the cheap ones until I cut through the u-bolt. I also had one of the bolts between the shorty headers and old Y-pipe locked on so bad I had to cut it in half.
Getting the Bassain Y-Pipe wan't fun either It just would nor cooperate. I finally did manage to get it in place.
The cat slid right in place. They included two stainless clamps to hold the cat and muffler in place.
The Flowmaster Super 40 was 2 1/4" in / out so I used a piece of 3" exhaust pipe and cut the opening to fit.
I ordered a 3" mandreal U bend from Jegs and cut in half to make two l bends. I also cut 8" off the pipe between the muffler and the cat.
I had to cut a little sheet metal to get it to exit out the corner of the wheel well. And out the side it goes. the piece I cut off the cat end fit nicely at the end.
Ta-Da!
I added a bracket to the tail pipe.
Ta-Da!
