Is is me or does the firing order difference between the 302 and the 351w make the exhaust sound totally different [not tone, but pulses]? The 351 sounds more "thumpy" and intermittant than the 302/289 to me. Opinions on this?
There's WAY too many factors involved, to even speculate on that - cam profiles, condition of the exhaust systems, exhaust pipe sizes, routing, mufflers, condition of the cats... there's more, but you get the idea
I'm running stock motor, 30" glasspacks with less that 5 ft. total length. It doesn't sound anything like any 289/302 I've ever had. It blabbers all offbeat like a harley in comparison.
I used to think the difference in sound had something to do with the firing order, but I can't see why. I sat down a while back and figured it, and if you look at each bank (left and right header), the exhaust pattern on both is still (every 90 crank degrees):
Psgr: fire wait wait fire wait fire fire wait
Drvr: wait fire fire wait fire wait wait fire
This is the same for both the old 302 (1-5-4-2-6-3-7-8) and 351/302HO (1-3-7-2-6-5-4-8) firing orders. The only difference is where in the cylinder sequence the pattern starts. On the passenger side header, the F-W-W-F part of the sequence starts with 3-7-8-1 on the 302 and 2-6-5-4 on the 351. Otherwise the pattern in each header is the same, and the two headers coordinate the same (i.e. not out of phase or anything).
I have to think the differences are mostly in cam timing. Most 351W's came with a more radical cam than the truck 302's, and are closer to the 302HO cam. I can almost always tell the difference audubly, but that's the only reason I can think why. I don't see any way it can be the firing order.
You definatly had a lot of time on your hands that day.:popc1:
Actually, I sat down and refigured it before I posted that just to make sure. Only takes about five minutes when you know the firing orders already. Maybe I should get out of the garage for a while, huh? :brownbag :toothless
