Those of you running extended radius arms what did you do with the stock brackets. I just extended my radius arm and I am going with heims on the ends. It looks like the stock brackets add alot of support for the trans crossmember. Should I cut them so I can still use them for support purposes or just get rid of them? :popc1:
www.easttn4x4.com
I cut them for clearance but left them there for the crossmember. I've got a set from a F250 which uses leaf springs that I might put on at some point.
scrounger extrordinaire
thats the tiniest picture i have ever seen
