1 - 2 of 2 Posts
OK, so I recently found out that I got a bad joint on one end of my drag link, and the one on the short drivers side tie rod.(rutted gravel roads are fuuuun like this... ;) ) Found good prices on those parts new and ordered them... But my whole setup is bent pretty good and adjusted to compensate for the bend... but if I throw in 2 out of 3 new straight parts, it ain't gonna adjust worth a damn with the other long tie rod still being bent..
Got a source for a dead cheap long tie rod from a 250/150 set;
So, will the long pass side tie rod from a 78 F250or F150 work on the bronco?
I'd simply go compare my 250 to the bronc, but the 250 is at a buddies shop right now and i can't get to it till mid week...
G.
I believe that a set from a 150 would work. I could be wrong but I think a 250 won't match up correctly with the bronco; I think the rod for the 250 is about an inch longer.
1 - 2 of 2 Posts
