1 - 9 of 9 Posts
1982 FSB 302, c6, NP208 manual, manual hubs, manual windows, 3.00 gears LSD rear, 235/75/15 HK ATM
I still have the factory radio. When I bought it I was told that it would need a tube to work properly. I know that the fuses are good, and it has the little green light on by the tuning knob. I have had it make a blip of noise by sliding the balance bar side to side. I would like to get this radio working before I put a retro sound unit in it. I did a search on this and didn't find what I was looking for. If anyone knows how to troubleshoot one of these I would appreciate the help!
Yes, it is still in the bronco. It doesn't have a tape deck just AM/FM. I mess with it every time I drive it with no luck.
I couldn't really tell, it might have just been the dash speaker.
Best bets going to be pull it and get it on the bench with a speaker and an antenna.
Why would you ever do that to yourself?
Drop in a new bluetooth radio (no dash cutting req) and stream music via bluetooth from your phone....done.
Addicted to Junk
An '82 AM/FM is likely a 2-post radio, and the bezel must be cut to accept a DIN radio. Then you have to get an adapter kit to support the radio properly. Its not quite as simple as in an 87+. Some later models like 84-86 did have a DIN cutout instead of the 2-post holes and slot.
I want to keep the factory radio look. I would rather put the 1000 or so that I plan on putting towards sound into other things right now.
1 - 9 of 9 Posts
