Hi Guys.......OK, here's one for you wiring experts. I'm re-installing a factory radio in my '91 Bronco that was removed by the previous owner. I replaced/repaired the OEM wiring harnessand plugs that had been cut (original plugs removed). I then found several OEM radios I could use.......... but here's the problem.
One of the radios I'd prefer to use is originally out of a '91 Ford Aerostar Van, which appears to be nearly exact to the Bronco radio. The reason I want to use the Aerostar radio is because it is much easier to find an Aerostar radio as oppossed to a Bronco radio. They are much more plentiful and have all the same features (clock, etc.). When I hook up the radio, the passenger side speakers do not work.......at all. However, if I hook up a OEM radio out of a same year Crown Victoria (also very similar radio but with out the clock), everything works fine. I tried a different Aerostar radio but with the same results. Passenger side speakers do not work. So, I'm assuming either I have two bad Aerostar radios, or there is some weird wiring thing going on.
Does anyone have any ideas?
Thanks........
Stuart
Portland, Oregon
Thanks........
Stuart
Portland, Oregon
