1 - 8 of 8 Posts
never mind the last post,, i had a brain fart, its not rich, never mind that
your posible causes are bad secondary ignition(plugs, wires, cap, rotor, coil)'
your EGR might be stuck on
timing could be off
vaccum leaks are also a possibilty
also, a motor with low compression that suffers from worn rings, burned valves, or a bad headgasket has the same issues...
:stupid
I didn't even know that you guys up in Portland had to pass emissions. I've seen a DEQ station once before up there but I didn't think everyone was required to pass emmissions. Luckily I don't where I live.
Crazed said:
We leaned it out a little bit then it passed.
This wasn't accompanied by a rambuntious time in the dirt <spinning tires> like someone else I know did, did it?
<eh, Todd?> :toothless
Did you end up passing it in Clackamas?
1 - 8 of 8 Posts
