1 - 9 of 9 Posts
Picked up a new to me 79 Custom. It's a rust bucket.
But it runs like new - seriously - I found a receipt for a NAPA reman engine from 2015 - poor guy paid $3k for the engine.
In any case - the rear quarters are shot & the front fenders are rusty.
I can find fenders easy enough if I look around - back quarters are kinda cheap too at less than $200 each - but what I'm wondering is this.
I see a lot of "fender flares" for sale - but they are mostly from chevy trucks & the occasional GMC - rarely a ford & never a bronco.
Has anyone tried to put GMC flares on their bronco? If I could pick up a full set for less than $100 I would cut away much of the rust - flapper disk the rest & hit it with some rustolium & keep on driving for a while.
I'm just trying to find a way to make it look a little better in the short run before I try & tackle replacing all of the body parts.
If you have - please share pics
Personally not a fan of flares, but there are plenty out there for 79 broncos
Most wheel flares I'm seeing are bolt on and definitely not under a hundred dollars... How much rust do u have to cut out? U would still need good metal to bolt to all while the rust continues to compromise more of your rig. I was always taught the more holes u put in ur rig the more u leave it succeptable to rust .
To me, it would make more sense to just pull the quarters and replace and put a rust converter on or replace whatever u find under the panel that could be compromised. Replacing panels isn't a terrible job (from what I hear) and u can get rear quarters from places like parts geek for $191... It would seem the wiser investment if you're hoping to have your rig for many more years.
If you’re going to replace the quarters in the future, just cut the rust out now and forego the flares. Then you’ll have a custom Custom.
Addicted to Junk
Bushwacker cut-outs for a 80-86 ford truck... they should fit a 73-79 with minimal adjustments. But not cheap new at about 100 for each flare.
4" lift and 37s
I appreciate the comments - but didn't really get an answer (or maybe no answer was the answer). Has anyone used existing flares from another vehicle & made them fit?
I will eventually have to put new quarters on - at least a full quarter on the passenger side & the bottom half of the drivers side.
But I'm not going to try & do that in the winter when the weather sucks. I would prefer to find a reasonable solution for under $100 that will get me through until I stockpile all the metal I will need (tailgate has been ordered).
Anyone?
By the way - Sharp looking 85. I have stock sized tires - so flares that big will look silly with tiny little wheels & tires under them.
Ford Hoarder
78 & 92
not mine
Had chevy or gmc factory flares on the rear... I have thought superduty or excursion flares would work ok as well.
On my 78, I have electrical conduit bent by hand with a slit cut in it, shoved this on the cut fender, then spot welded it to the quater panel in several places. This gives it a nice edge and also some much needed rigidity to the panels after being cut.
Addicted to Junk
Well an 85 is a different vehicle, technically lol.
I would think the GM flares would work pretty well, and keep the square wheel wells.
not mine
Thats it! Those back flares look good!
This is expected to be a temporary (could be a year or two) solution that doesn't cost much. No need to throw money at a temp solution.
Thanks for this!
Addicted to Junk
Some people have used that black garden edging plastic stuff as flares with good success too
1 - 9 of 9 Posts
