my my, werent you a busy boy. looks good. did you cut out the rust or just lay it right on top? so this is a temp fix?
I ground down some of the rust. But not a lot. To remove all of it would remove the entire panels. Plus the rusty panels gave the fiberglass shape.SquattyD said:my my, werent you a busy boy. looks good. did you cut out the rust or just lay it right on top? so this is a temp fix?
other than loose flakes, it'll pretty much adhere to anything.Fireguy50 said:I ground down some of the rust. But not a lot. To remove all of it would remove the entire panels. Plus the rusty panels gave the fiberglass shape.
How do you hold them to shave them?Sixlitre said:Have you discovered "kitty hair" ?
Sixlitre
Ooch it's no difficult fer a ScotsmanBlueBronco said:How do you hold them to shave them?
:shrug
