Howdy! brand new bronco owner. 93 XLT. very excited and also very happy to have found this forum!
First thing I gotta fix is the tailgate panel seems to be from the previous generation bronco. Pre 87 I guess.
I know the tailgates themselves are interchangeable from the different years, and I also know this isn’t the original tailgate. Are the tailgate panels also interchangeable? I don’t want to buy an 87 To 96 panel and then not be able to fit it on my truck!
thanks!
Yo ShenValleyBronco,
Welcome!
Your bottom trim panel fits 84 through 86 Broncos
169833
169834
Swapping (t'gate differences between the years); "...Amazingly throughout the number of body style changes from 78 through 96, the tailgate remained nearly the same. You can swap tailgates between all of these years taking note of the following: I've broken down the 3 major changes into their respective years. 78-79 Type A; 80-82 Type B; 83-96 Type C; If your swapping within the same type it's just a direct swap. If swapping A & B you have to switch the glass and glass support brackets; If swapping B & C you have to switch latches and striker plates; If swapping A & C you have to switch the glass, glass support brackets, latches & striker plates..."
Source: by Mike M (MRM) at his old medicine.wisc.edu site
94-96 aftermarket tailgates have carpet push-pins holes, causing aftermarket interchange to stop at 1993 model year. So in say, 93 tailgates, you need to drill outside holes for a trim panel, and drill inside holes if you want to install carpeting pad.
ASAP find out if speed control, if equipped, recall work is completed. Check @ Recalls Look-up by VIN (Vehicle Identification Number); or @ Welcome to Ford Owner | Official Ford Owner Site; or ... have VIN ready. While there, see most Ford dealer maintenance/repairs done @ any dealership nation-wide.
See this guide by jowens1126 to confirm recall status @ 93 & 94-96 Cruise Control Recalls Repair
For any Bronco questions or to chat about desired modifications or build, it's better to post each seperately in Noobie Bronco Tech Questions. Flame free zone. This will get more attention and you can build up your post count to get into other sections such as Bronco and Ford Parts/Accessories (75 posts required to participate due to scammers who preyed on our members ).
Here is the 1993 Bronco Dealer Brochure in Google Drive @ 93Bronco.pdf
1993 Bronco Dealer Training Video via silver70 @
1993 Bronco, Venezuela Commercial @
Our Forum FAQs includes for example, How To Upload Images To Posts & How to Use Search. See more tips!
Baba Looey's Favorite FSB Links (lots and lots of tech links)including, "how do I get the tailgate glass to...", etc
Try to find time to participate in our Full-Size of the Month Contest and ongoing Full-Size of the Year Contest @ Voting
See pictures & build info of each Bronco nominated.
You will get ideas by those competing. Also see the prizes! They are awesome as compared to other sites' "contests"!
Al
Thanks for all the info!
So my Bronco is a 93 XLT (but 99% sure it's not the original tailgate). It currently has a panel like this, which if it's for an 84-86 I want to update - but it also sounds like the correct year trim might not fit my tailgate (since it's currently rocking an 84-86 panel). Guess the only way to know is pop it off!
169835
