Thanks again Miesk5. I haven't even gotten her burped yet. I work 12 hr shifts @ a power plant and this is my night shift weekend so I'm planning to get to the bottom of this tommorow.
I replaced the t-stat when I replaced the water pump less about 1000 miles ago. I will however verify true coolant temperature since I recently purchased one of these
http://www.summitracing.com/parts/MRG-2471B/. My guage well, you know, it's my guage:banghead, it goes to normal as soon as I turn the key on (just like my oil pressure is normal when the truck ain't even running and key on)!:histerica Read the threads on that too so I know not to trust anything on my instrument cluster til I can install some aftermarket guages.
Will post results.....
yo,
yw,
Look in my site @
http://www.broncolinks.com/index.php?index=649 for the 96 Bronco coolant temperature gauge/sender test Link
Instrument Cluster Connector C1
Pin Number Circuit Circuit Function
1 904 (LG/R) Charge Indicator Lamp
2 932 (GY/W) High Beam Indicator Input
3 57 (BK) Ground
4 450 (DG/LG) Fasten Belt Indicator Input
5 29 (Y/W) Fuel Level Input (with Tachometer)
6 19 (LB/R) Instrument Cluster Illumination Input
7 57 (BK) Ground
8 2 (W/LB) Right Turn Input
9 648 (W/PK) Tachometer Input Signal
10 398 (BK/Y) Tachometer Ground (for 8 Cylinder)
11 784 (LB/BK) Low Range Indicator Input
12 210 (LB) 4x4 Indicator Input
13 640 (R/Y) Power Supply in RUN and START
14 16 (R/LG) Charge Indicator Input
see Image k20303c for Instrument Cluster Connector C2
1 875 (BK/LB) Unique Ground to Gauges
2 658 (PK/LG) "Check Engine Indicator" Input
3 603 (DG) Anti-lock Brake Warning Indicator Input
4 977 (P/W) Brake Warning Indicator Input
5 � Not Used
6 29 (Y/W) Fuel Level Input (Without Tachometer)
7 3 (LG/W) Left Turn Input
8 31 (W/R) Oil Pressure Input
9 875 (BK/LB) Unique Ground to Gauges
10 39 (R/W) Temperature Input
11 531 (DG/Y) Brake Level Switch Input
12 608 (BK/Y) Air Bag Indicator
13 640 (R/Y) Power to Gauges, Hot in START or RUN
14 � Not Used
and; Pull the R/W wire off sender; ground it; turn the key to Run. If needle pegs, replace the sender. If not, diagnose the circuit.
-- OIL PRESSURE;
Test & Overview in a 96 from 1996 F-150, F-250, F-350, Bronco, F-Super Duty Motorhome Chassis Workshop Manual: The oil pressure gauge is a magnetic movement design consisting of a bobbin/coil assembly, a return to zero magnet and a primary magnet. The shaft and pointer are connected to the primary magnet. The bobbin/coil assembly is pressed into a metal housing which has two holes for dial mounting. The gauge operates through a pressure activated switch. When the engine is started engine oil pressure closes the switch, providing a ground circuit for the gauge coil. Current flow through the gauge coil to ground causes the primary magnet and pointer to rotate, providing an oil pressure reading on the dial face. The oil pressure gauge does not require adjustment, calibration or maintenance. Also, never remove the pointer indicator from its shaft. The oil pressure switch controls the magnetic oil pressure gauge's pointer position. The oil pressure switch closes under normal engine operating conditions (oil pressure above 42 kPa [6 lb/sq in]). The oil pressure switch opens with the engine (6007) off and no oil pressure. Check gauge operation as follows: With the key in RUN and the engine off, disconnect wiring connector at the switch. The gauge should indicate on the LOW graduation or below. Connect the wiring connector to the engine block ground. The gauge should indicate just slightly above mid-scale. If the oil pressure gauge tests within calibration, replace oil pressure switch. If the gauge still tests out of calibration, replace oil pressure gauge.
Source: by Ford via miesk5 at FSB
more @
http://www.broncolinks.com/index.php?index=949
Other Gauges and Indicators @
http://www.broncolinks.com/index.php?index=429
