1 - 14 of 14 Posts
i just thought i'd share some of my project, so here it is...i got my 78 this fall and got the fenders trimmed out mostly to remove rust, but also to clear the 35's...;) so here's some pics of the process...
before (i'm not sure why we took the hood off...:toothless )
i did the back, and my roommate did the front...
also some custom exhaust work, that leaks about as much as it did with no exhaust...when i brought it home it was open manifolds...very loud :rockon.
the next issue is fixing this crack in the frame...the p.o. had a plow on it, and i don't think it was well taken care of...at all. :twak
oh, and the floors need "some" help...(thanks to the roommate for pointing it out...:thumbup
but it works...i even made it through on my own, the old posi's must still have something left to them...:drinkbud here's how it sits on 35x12.5's
Engineer
Looks pretty sweet
broncofied
Looks good with the 35's but wow yo got some rust:banghead
thanks guys:drinkbud , it's definately a project, the tailgate is a complete loss due to rust, the rust on the side is almost all surface rust though, and the floor boards will be cut out and new ones welded in soon hopefully...the cool thing about the paint is that it's the same scheme as my first bronco (1987) was, i plan on doing all the body work and repainting it to the original blue/white this summer along with installing the 4" lift in my garage back home...:rockon
edit: and i've got a guy lined up to build custom bumpers front and rear for it too...:thumbup :rockon
draw a line, then cut on that. it helped me a lot. there's also some metal bracing inside the fender that was a pain to cut around, so i ended up cutting most of it out. and have plenty of cutting disks if using an angle grinder, and take your time, i found gloves and safety glasses to be helpful too...:thumbup
:drinkbud
:drinkbud
If you don't have an angle grinder a jig saw with metal cutting blades works pretty well. And if you have a good paint job that you care about put tape over where you want to draw your line and cut. That wil protect the paint while your cutting.
The mud covers up the rust nicely :D but looks good
Stuck like a MoFo
i would be jumpin on the frame issue immediatly. Drill hols at the ends of the crack, v it some with a grinder and fill it in. I would also bolt/weld a piece of flat plate or c-channel on the inside and outside of the frame, just to take care of any possible issues
Discussion Starter #13
i was thinkin the same thing...:toothless
:drinkbud
1 - 14 of 14 Posts
