1 - 9 of 9 Posts
I did a quick search on this and didn't find what I was looking for, so maybe yall can answer a quick question for me. When I rebuild the 302 in my 89 bronco I plan on using that comp cams SD freindly cam and using flat top pistons, if the block needs to be bored over. Will I have any running or idling issues with flat tops instead of buying new dished pistons like the factory ones? I figure I won't just something I have to ask and make sure.
Thanks for the help.
Who needs oil anyways....
You'll want to make sure your heads will work with the flat tops. Other than that I wouldn't think you'd have any problems. It will probably change your compression ratio a tiny bit.
Cadillac of Men
piston to valve clearance shouldnt be a concern with stock heads and valves. the flattops will prob have reliefs in them.
your only concern will be your compression ratio. it will jump a little bit, depending on how much of a dish you have in your pistons now.
Yeah, that is what I was referring to. I mentioned it because you didn't say if you were keeping the heads stock. I went to flat tops with my stock 351W heads. The pistons have the relief SquattyD mentioned. They work fine. Just wish I had a 427 stroker instead of just a 351 bored .030 over. :thumbup
Speed density? Not sure what you mean.
Discussion Starter · #8 ·
I mean with a little more compression will it through off the computer and have a problem idling and running. I wouldn't think so but I just need to know from people on here who have done this that it will run right.
Thanks.
1 - 9 of 9 Posts
