1 - 3 of 3 Posts
my Bronco is a 79 w/400. I know that there is a different oil pan for the Bronco because the oil pump hump is in the middle instead of the front. Mine is unfortunatley the wrong one . I know this because it has a dent in it the exact same shape as the front axle . My quetsion is, is it possible I just have the wrong oil pan or is the motor probably a wrong replacemnent? Any suggestions on a remedy?
Also what is involved in changing the axles cover gaskets and tranfer case (gasket???). Any cleaning the gunk techniques?:beer:drinkbud
shoulda put this one in the 78/79 forum.
the bronco needs a rear sump pan. If you have a front sump then your pan came from a care. If my memory serves me correctly.
1 - 3 of 3 Posts
