3 hubs
3 rotors
3 spindles
3 sets of wheel bearings
2 caliper brackets
$180
bolts onto you 77.5-79 d44 front axle. uses same knuckles, axle shafts, and locking hubs as your current 5 lug stuff.
no calipers
‘95 xl, 5.8l, ZF S5-47, BW1356, SAS, D44(8lug), Sterling 10.25 (Detroit)
Zach,
Are these the ones you grinded to clear 15" rims?
I might take them off your hands.
Can you get me an estimated shipping cost to 32726?
What BS did you have to run on the rims?
-matt
ya, they where clearing 15" with 2 3/4 backspacing. i sold the calipers to my friend cause he needed calipers for his D60's for a competetion a while ago.
all you need is calipers adn this setup is good to go.
weight is probably about 100-120 lbs
ouch, shipping looks to be about $72
calipers are gone, and the little hold down slips are gone.
i can go swipe the hold down clips off a J yard 2wd truck if you want....
the rotors may not be the greatest, but the spindles, hubs, and brackets are all great.
I am interesed in the parts, however I have a couple of questions. How much if any were the caliper brackets ground down for 15" wheel clearance? Would you be willing to sell a pair for less? I'm in CA(94583) so shipping cost is a concren. About how much does each rotor/hub set weight? I want to try to estimate the # of boxes and cost for shipping. Thanks.
acually a member has called dibs on them, and they are sold.
i will get back to you if he backs out. but total weight is near 110lbs, the caliper brackets themself have hardly even been knicked with the grinder, it was 90% on the calipers, and the caliper lock pin.
