1 - 4 of 4 Posts
hello all this is my first post on this forum, and i must this this site is awesome...
ok now to the point, I have a f-100 that has a 360 in it and a 4 speed tranny with a granny gear.
will The motor and tranny be a direct swap to a bronco?
And can someone give me some information on the motor and tranny...
Thanks,
Zach
FSB warrior
You didnt mention whether the F100 is 4wd, if not then no it wont be a direct swap. I think you can get an FE in the engine bay of a bronk, probably just have to use F150 mounts, but the Engine and trans must go together in that case. FE, M and 460, and Windsor are each different bellhousings.
Sway Is My Fan Club.
You also didn't mention what year the Bronco is. If it's a 78/79 model it will be easier, but unless you're good at fabricating and figuring out things, the swap is not cheap.
If it's a 78/79 model Bronco, check out www.ProjectBronco.com, they have a forum dedicated to those running the FEs.
And welcome GA boy, to FSB. :thumbup
A friend of mine has a 79 bronco with a 390 and a 4spd in it. Don't do it. He likes it ok but routine maintenance can be a pain. Like replacing a starter. Just find a 351M or 400 with a 4spd already behind it. You'll be happier.
1 - 4 of 4 Posts
